Pixhawk 无响应,B/E IO 上的红色 LED 常亮
可能是什么问题?我的 Pixhawk 4 偶尔会无响应。以下是 mavros 的日志输出:
MAVROS UAS via /uas1 started. MY ID 1.240, TARGET ID 1.1
[starter-2] [INFO] [1773031437.488168571] [starter]: Starter Node started
[mavros_node-1] [WARN] [1773031438.964811103] [mavros.sys]: VER: broadcast request timeout, retries left 4
[mavros_node-1] [WARN] [1773031439.965010277] [mavros.sys]: VER: broadcast request timeout, retries left 3
[mavros_node-1] [WARN] [1773031440.966867710] [mavros.sys]: VER: unicast request timeout, retries left 2
[mavros_node-1] [INFO] [1773031441.720605108] [mavros_router]: link[1000] opened successfully
[mavros_node-1] [INFO] [1773031441.720765180] [mavros_router]: Requested to add endpoint: type: 1, url: udp://@192.168.1.2:14550
[mavros_node-1] [INFO] [1773031441.720842336] [mavros_router]: Endpoint link[1001] created
[mavros_node-1] [INFO] [1773031441.721426652] [mavros_router]: link[1001] opened successfully
[mavros_node-1] [INFO] [1773031441.721479903] [mavros_router]: Requested to add endpoint: type: 2, url: /uas1
[mavros_node-1] [INFO] [1773031441.721526625] [mavros_router]: Endpoint link[1002] created
[mavros_node-1] [INFO] [1773031441.725171763] [mavros_router]: link[1002] opened successfully
[mavros_node-1] [INFO] [1773031441.943420071] [mavros_router]: link[1002] detected remote address 1.240
[mavros_node-1] [WARN] [1773031441.965247919] [mavros.sys]: VER: unicast request timeout, retries left 1
[mavros_node-1] [INFO] [1773031442.381910800] [mavros_router]: link[1001] detected remote address 255.190
[mavros_node-1] [WARN] [1773031442.964829660] [mavros.sys]: VER: unicast request timeout, retries left 0
[mavros_node-1] [WARN] [1773031443.966942407] [mavros.sys]: VER: your FCU don’t support AUTOPILOT_VERSION, switched to default capabilities
我对 Pixhawk 4 和 MAVROS 系统不太熟悉,但如果我没记错的话,Pixhawk 上的“Bootloader / Error”指示灯会在固件启动过程中出现错误时常亮红色。您最近尝试过将固件刷入 Pixhawk 吗?刷写过程可能没有成功完成,在这种情况下,您可能需要再次尝试刷写。如果几次尝试后问题仍然存在,那么可能是您使用的固件或主板本身存在问题。
经过多次固件刷新和测试,目前我可以断定问题与Pixhawk主板在AUV管内过热有关。因为当我们把Pixhawk从管子里取出放置1小时后,问题就消失了。
